TomTieDom
Jun 17, 2021Aspirant
Incoming connections but no ports forwarded or UPnP enabled X6 R8000
Hi, I notice incomming connections in the access log like this: [LAN access from remote] from 193.107.216.203:5138 to 192.168.100.5:5060 192.168.100.5 is my VoIP phone and in the past I had por...
- Jun 17, 2021
Thanks for the idea. i did not have a DMZ server configured, but in the same configuration screen (see picture) I noticed the NAT Filtering option. I checked "Disabled SIP ALG". Hopefully this solves the issue.
For some reason including a picture in the text does not work so I attached it as a file.
Cheers,
Marnix
antinode
Jun 17, 2021Guru
> [...] no port forwarding or triggerig rules enabled nor do i have UPnP
> enabled.
A DMZ server would be another way to allow incoming connections.
A settings reset and manual reconfiguration is the usual shotgun to
employ when the displayed settings disagree with the actual behavior.
- TomTieDomJun 17, 2021Aspirant
Cheers,
Marnix
