riker1910
Feb 04, 2021Aspirant
Incorrect MAC Addresses being shown on Netgear R7800 router
Hi I have noticed connected devices to my wifi network (Mac addresses of each device) don't display the same MAC address when viewing on the "Access Control" page within Router Administration pro...
- Feb 04, 2021
> The only thing I can think of is that I do have a Netgear Extender
> upstairs....could this be causing the mismatch in MAC Addresses?It's part of extender operation. See, for example:
A Web search for terms like, say:
wireless extender spoof mac address
might be educational.
riker1910
Even more puzzled now....removed all devices from the "View list of allowed devices not currently connected to the network" list
which included my spoofed MAC address for my iphone (when the extender was in play)
Turned off iphone, refreshed router Access Control page - device disappeared from the Allowed Connected list, and went into the
"View list of allowed devices not currently connected to the network" list.
Turned off iphone again and back on and now another MAC address (which is different again!!) has appeared in the Allowed Connected list.
and it's not the REAL iphone Wifi MAC address!!
antinode
Feb 04, 2021Guru
> [...] and it's not the REAL iphone Wifi MAC address!!
Define "real".
https://support.apple.com/en-us/HT211227
Everything's complicated.
- JuanHerreroFeb 04, 2021Tutor
I have just been setting up a Netgear RAX80 router, and when I look at Attached Devices, the MAC addresses are all wrong. I want to force specific IP addresses for various devices - which MAC address should I use? The correct ones or Netgear's weird ones??
For the avoidance of doubt, my definition of "correct" is the MAC address shown in the device, which also displays correctly on my Netgear R7800 at a different location.
- antinodeFeb 04, 2021Guru
> I have just been setting up a Netgear RAX80 router, [...]
Ok. Are you using a wireless extender as was the fellow who opened
this thread? Are you using an Apple iOS device? Why did you join this
thread instead of starting your own?> [...] the MAC addresses are all wrong. [...]
I can't see them from here. Which kind of "all wrong"? Wired or
wireless devices? Always the same MAC address for a particular device
on a particular router?> [...] I want to force specific IP addresses for various devices -
> which MAC address should I use? [...]The router sees what the router sees. Which one works?
> [...] displays correctly on my Netgear R7800 at a different location.
Apple's "private Wi-Fi address" feature is specific to "each Wi-Fi
network." Without more information than "I'm unhappy", it's tough to
guess what's causing what you (only) are seeing.- JuanHerreroFeb 04, 2021Tutor
It would be useful if someone helpful could reply, not someone (purporting to be a guru!) who just wishes to pick at the content of a question to prove how clever he/she is.
- riker1910Feb 04, 2021Aspirant
Thanks antinode....bloody apple......that's the issue so know what's happening now...
> [...] bloody apple [...]
Hey. They're _helping_ you. On the bright side, if you don't want
the greater privacy, then you can disable the feature.
