riker1910
Feb 04, 2021Aspirant
Incorrect MAC Addresses being shown on Netgear R7800 router
Hi I have noticed connected devices to my wifi network (Mac addresses of each device) don't display the same MAC address when viewing on the "Access Control" page within Router Administration pro...
- Feb 04, 2021
> The only thing I can think of is that I do have a Netgear Extender
> upstairs....could this be causing the mismatch in MAC Addresses?It's part of extender operation. See, for example:
A Web search for terms like, say:
wireless extender spoof mac address
might be educational.
antinode
Feb 04, 2021Guru
> I have just been setting up a Netgear RAX80 router, [...]
Ok. Are you using a wireless extender as was the fellow who opened
this thread? Are you using an Apple iOS device? Why did you join this
thread instead of starting your own?
> [...] the MAC addresses are all wrong. [...]
I can't see them from here. Which kind of "all wrong"? Wired or
wireless devices? Always the same MAC address for a particular device
on a particular router?
> [...] I want to force specific IP addresses for various devices -
> which MAC address should I use? [...]
The router sees what the router sees. Which one works?
> [...] displays correctly on my Netgear R7800 at a different location.
Apple's "private Wi-Fi address" feature is specific to "each Wi-Fi
network." Without more information than "I'm unhappy", it's tough to
guess what's causing what you (only) are seeing.
JuanHerrero
Feb 04, 2021Tutor
It would be useful if someone helpful could reply, not someone (purporting to be a guru!) who just wishes to pick at the content of a question to prove how clever he/she is.
- antinodeFeb 04, 2021Guru
> question to prove how clever he/she is.The forum software determines those ranks, not the participants. I
purport nothing.Also helpful would be starting your own thread for your own problem,
and including some useful information in it. In any case, answering
those pesky questions would be more helpful than all the indignation you
can muster.Appending your query to a thread which has been marked "Solved!"
might not be the best way to attract the attention of other
participants. Unless, that is, you're depending on psychics. I suppose
that if they're good enough to find your information-free problem
description, then they might not need more information from you. - JuanHerreroFeb 04, 2021Tutor
QED
