DaveTheJHJ's avatar
DaveTheJHJ
Follower
Aug 18, 2021
"Incorrect password" message
I think  I've locked myself out of my R6400/AC1750 router. I'm getting an "incorrect password" message. I'm using the network name and network password on the bottom of the router. How do I fix this? Thanks for your help!
1 Reply
  • plemans's avatar
    For the wifi or to log into the device using the gui?
    You can always factory reset and start over. Push and hold reset for 7-15 seconds while its powered on.
    then reinstall it
