Fregalbuto
May 18, 2021Aspirant
Incorrect Password
One second it was working and the next I was booted off the wifi. When trying to reconnect it keeps saying incorrect wifi password. This is happening on my Mac and my iPhone. I even tried doing the Sh...
May 19, 2021Guru - Experienced User
do wired devices work?
Is it only the wireless ones with issues?
- FregalbutoMay 19, 2021AspirantI do not have any hard wired devices. I have a laptop, iPad, Mac, and gaming device that connect to the router via wifi only.
- plemansMay 19, 2021Guru - Experienced User
then I'd find a way to wire one in. Either with a usb-->etherenet adapter, using an actual ethernet port (if they have one), or even borrowing a laptop to tests.
What modem do you have it connected to?
What firmware is on the router?
When you reset, did you push reset while it was powered on?
What are all the led's on it doing?
