glnc222
Sep 28, 2020Aspirant
Incorrect Update Instructions Nighthawlk
Instructions for firmware updating with browser instead of phone are incorrect. It says to connect the PC to the router with an ethernet cable. When this is done, the login page says it must be con...
- Sep 29, 2020
Thanks for references. The email from Netgear was
"We've Enhanced Your Product's Security.
Please Update to the Latest Firmware.
Your product has the following updates available:
R6080
Learn how to update here
Latest firmware version: v1.0.0.46
Use the Nighthawk App to update your firmware
App Store
Google Store
If you don't have an iOS or Android capable device, visit this page."
Also a video with instructions
https://click.e.netgear.com/?qs=085694c93a37852e173953e623794457027cbc5db866928f89e530a9118b1914be0fdb61a17c534de2609d3cdfaa667d9a4cc07c93401497
antinode
Sep 28, 2020Guru
> [...] An email received [...]
Not by me. With my weak psychic powers, I can't read your e-mail.
> [...] They log into the router using web address routerlogin.net or
> routerlogin.com, [...]
That doesn't always work, as explained in the above-cited thread
(along with alternatives):
> https://community.netgear.com/t5/x/x/m-p/1976674
> [...] The product label also shows a password, [...]
Again, I can't see at what you're looking.
I'd expect the product label to show two (different) types of "a
password", as explained in the User Manual, under "Types of Logins", as
suggested above.
> [...] it shows an error screen saying the connection must be by WiFi,
> despite the instruction article saying to use a cable. [...]
Which is why it has been described (in the above-cited thread) as
"what may be the worst error message in the world".
Yes, some Netgear documentation stinks. You could pout or complain
about this. Or, you could find and read additional information which
should let you get on with the task at hand.
glnc222
Sep 29, 2020Aspirant
R6080
App Store
Google Store
