astnmartin23
Feb 14, 2021Aspirant
INCREDIBLY SLOW WIFI SPEEDS
Hello, I’m experiencing incredibly slow Wi-Fi speeds on all my wireless devices using the Netgear Nighthawk AX5400 Wi-Fi Router (RAX50). I have “1Gbps” internet through Xfinitiy and have run a multi...
Feb 14, 2021Guru - Experienced User
What modem/gateway is it connected to ?
What firmware version are you using?
Have you tried changing which 5ghz channel your on?
Another option is a factory reset and clean install. the RAX devices were released before the AX spec was even finalized. They respond very favorably to factory reset and clean install (not from backup)
