tosh30
Aug 12, 2021Aspirant
Insight basic portal issue
I have a Guest SSID that works as an open network. When I turn on captive portal, that works too. When I turn on and add a Redirect URL, the redirect does not work at all. Any issue with this fiel...
- Aug 13, 2021
I'll repeat the process in the Insight community page. Marking this as Resolved to close it here.
michaelkenward
Aug 13, 2021Guru - Experienced User
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
or even here:
NETGEAR Insight Network Management - NETGEAR Communities
The WAC540 isn't much like the routers covered in this section and Insight is its own thing.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- tosh30Aug 13, 2021Aspirant
Thanks for the advice, and for asking the moderator to move the message. Didn't realize that I selected the wrong category, as my eyes were red from trying 100 ways to get it to work.
- michaelkenwardAug 13, 2021Guru - Experienced User
Easily done. This place is a mess.
