dhs
May 24, 2021Aspirant
install Cove security cameras via wifi with NetGear R6120.
NetGear R6120 router. Trying to pair Cove security cameras. SSID will not "pre-populate" in the Cove phone app where it's supposed to. My phone is connected to the wifi. Can't access the field on the...
- May 25, 2021
Turns out it was their app the whole time. The 3rd rep I s/w at Cove informed me of the app error. What a hassle. They had me chasing shadows for hours, when the problem was on their end the whole time.
Installed cameras with no issue using YI Home camera app.
vjramsas
May 25, 2021Initiate
Try changing the wireless channel under 2.4 ghz on your router to 6 or 9 or 11 and update the settings and check whether you could find the network on clove app. sometimes happens due to interference.
