walt_hill
Mar 28, 2020Aspirant
Install flash drive on USB port of C7000
Model C7000 Windows 10, firmware V1.01.33 I'm trying to set up a Kingston DataTraveler 8G flash drive on the USB port on the router as a \\readyshare but it can't be found on my network. My PC is w...
- Mar 28, 2020
Yes, it's formatted as FAT32 so it should be compatible.
plemans wrote:do you have it formated properly?
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
Mar 28, 2020Guru - Experienced User
walt_hill
