RuthJohnson's avatar
May 16, 2019
Installing Nighthawk AC2300 without a smart phone
Believe it or not, I do not have a SmartPhone.  How can I install this Nighthawk AC2300 router without one?  Is there an instruction sheet I can dowload and print?
  • antinode's avatar
    May 16, 2019
    > Believe it or not, I do not have a SmartPhone. [...]
       How about a computer with a web browser?
    > [...] this Nighthawk AC2300 router [...]
       Is that a model R7000P?  Look at the product label.
    > [...] Is there an instruction sheet I can dowload and print?
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.
