sampotter01
Jan 22, 2022Follower
Installing Resource CD without Admin Privilege's
I have a computer that we do not know the Admin user password. When installing the Resource CD there is a screen that requires Admin access to setup the software that is needed to run the WiFI Adapte...
Jan 22, 2022Guru - Experienced User
then you might be screwed. If your computer requires admin privileges to install software to it and you don't have that, it might not work.
You can try installing the stand alone driver and see if that'd work.
