cadguy82's avatar
cadguy82
Installing USB Device(s)
There is only 1 usb port.  CAN YOU INSTALL A PRINTER AND AN EXTERNAL DRIVE TO THE NIGHTHAWK AC2400 AT THE SAME TIME using a 4 port usb connector?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    It is not suggested but if you do make sure the USB hub is powered.
