nbsimons
Jun 29, 2022Aspirant
Integrating Netgear NightHawk R7000 downstream from network switch downstream from other router
Hello, I am working on upgrading my wireless network to include wired connections for high-demand devices. The primary router that I am using is an ISP-provided Plume mesh WiFi router. I had pr...
- Jun 30, 2022
FURRYe38 -
Thanks for the suggestion.
After getting some sleep and starting fresh, I tried a clean reset of the TL-SG108E switch and the R7000. After letting the switch boot, I connected the other downstream switches and confirmed successful connection. I then configured the R7000 in AP mode using the same settings I tried before. For whatever reason, everything worked this time around. I am not sure if there was initial boot time on the switch or router that I was not giving adequate time to complete or what.
But for now, the the network is up and running so I am not going to argue with apparent success.
Thanks for your time!
nbsimons
Jun 30, 2022Aspirant
FURRYe38 -
Jun 30, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
