6Monroes
Dec 10, 2018Aspirant
interferes with phone system
Ever since I installed the Router, my phone system has been acting up. I use 8x8 VoIP. THey seem to think the problem is the router and the setup. I am not sure if that is it or something else. Any ...
- Dec 11, 2018
Disable the SIP ALG, then cold boot your VoIP phones again.
How to disable SIP ALG on your NETGEAR device using the genie interface
IrvSp
Dec 10, 2018Master
Well, I don't know what you have in the way of the VioP system, but I'd suggest posting the the correct forum, https://community.netgear.com/t5/Cable-Modems-Routers-and-DSL/ct-p/en-home-dsl-and-cable-modems. In addition, supply some real information, "my phone system has been acting up" doesn't convey to me anything to even suggest.
Also say what you had when it did work and what was changed? General router settings as well would help so maybe someone could suggest what to change.
