6Monroes
Dec 10, 2018Aspirant
interferes with phone system
Ever since I installed the Router, my phone system has been acting up. I use 8x8 VoIP. THey seem to think the problem is the router and the setup. I am not sure if that is it or something else. Any ...
- Dec 11, 2018
Disable the SIP ALG, then cold boot your VoIP phones again.
How to disable SIP ALG on your NETGEAR device using the genie interface
michaelkenward
Dec 11, 2018Guru - Experienced User
Your footer says that you have a C7000.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. This is easily done, given Netgear's impenetrable community structure.
The C7000 is a Cable Modem/Router.
You might get better replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
