6Monroes
Dec 10, 2018Aspirant
interferes with phone system
Ever since I installed the Router, my phone system has been acting up. I use 8x8 VoIP. THey seem to think the problem is the router and the setup. I am not sure if that is it or something else. Any ...
- Dec 11, 2018
Disable the SIP ALG, then cold boot your VoIP phones again.
How to disable SIP ALG on your NETGEAR device using the genie interface
schumaku
Dec 11, 2018Guru - Experienced User
- 6MonroesDec 11, 2018Aspirant
Thank you. That solved my issue
