Username0
Aug 04, 2021Follower
Intermediate connection issues
My internet connect started dropping a couple days ago. I have checked all wires, completed a factory reset and internet provider resent signal out. Has anyone come across this issue and found a resolution?
1 Reply
Do you have a screen snip of the modem cable connections page and the event logs?
That helps us to check the signal from the ISP?
Is it only wired devices that drop? wireless? both?
