wgoat27
Jan 18, 2021Aspirant
Intermittent connection issues
My internet connection has been spotty/unstable and I have no idea why. My equipment: C7000 – Nighthawk AC1900 WiFi Cable Modem Router (Firmware Version V1.01.32) connected via wall jack Spect...
mattk2006
Jan 25, 2021Aspirant
Also found this post:
Solved: SYNC Timing Synchronization failure - Virgin Media Community - 4149017
might be an issue with the phyical connectoin or connectors
wgoat27
Thanks for your input, Matt.
The fact that I'm having issues on a hard-wired PC and Wi-Fi-connected Chromebook (as well as my Android phone) tells me the issue is either with the Netgear device or the Internet service itself.
This weekend I replaced my coax (wall to modem router) and Ethernet cable (cat 5E patch to cat 6, now connected directly from the modem/router to the PC) and my problems persist. The only thing that seems to have helped a little bit is moving my Chromebook from the 5G band to the 2.4G band. I've still had drops, though, so I dunno.
I posted a similar thread on the Spectrum user forum. Had a little more engagement over there, but still no solutions. https://community.spectrum.net/discussion/168825/need-help-diagnosing-intermittent-connectivity-drops/p1
