MauleGuy
Dec 27, 2021Apprentice
Intermittent connection problems after v1.0.4.46 firmware update
I updated my firmware to v1.0.4.46 but have been getting strange issues when trying to log on to certain websites. I often have to click numerous times to get on a site and often on login sites I...
- Dec 28, 2021
Problem solved. Netgear R7900 sitting in a box ready to be donated to a charity that supplies computer supplies to people in need.
Factory reset should solve the issue for re-use.
Dec 27, 2021Guru - Experienced User
A couple things to try.
1. enable ipv6 if you haven't and reboot the router/devices.
2. factory reset the router. Maybe an old setting is causing the issue.
3. downgrade the firmware. Maybe the latest did introduce an issue. You can always downgrade.
- MauleGuyDec 28, 2021Apprentice
I thought the firmware update was to correct security issues. Rolling back to an earlier update seems to defeat the purpose.
I have pretty much had it w/ Netgear's lack of respect for their customers. Next stop is a new routher NOT Netgear.
- vmartinezjrJan 03, 2022Aspirant
MauleGuy wrote:Problem solved. Netgear R7900 sitting in a box ready to be donated to a charity that supplies computer supplies to people in need.
I am having the same issue since the update. my version is V1.4.2.84 Any resolutions other than donating it?
