MauleGuy
Dec 27, 2021Apprentice
Intermittent connection problems after v1.0.4.46 firmware update
I updated my firmware to v1.0.4.46 but have been getting strange issues when trying to log on to certain websites. I often have to click numerous times to get on a site and often on login sites I...
- Dec 28, 2021
Problem solved. Netgear R7900 sitting in a box ready to be donated to a charity that supplies computer supplies to people in need.
Factory reset should solve the issue for re-use.
MauleGuy
Dec 28, 2021Apprentice
I thought the firmware update was to correct security issues. Rolling back to an earlier update seems to defeat the purpose.
I have pretty much had it w/ Netgear's lack of respect for their customers. Next stop is a new routher NOT Netgear.
MauleGuy
- vmartinezjrJan 03, 2022Aspirant
MauleGuy wrote:Problem solved. Netgear R7900 sitting in a box ready to be donated to a charity that supplies computer supplies to people in need.
I am having the same issue since the update. my version is V1.4.2.84 Any resolutions other than donating it?
- MauleGuyJan 03, 2022Apprentice
The only recommendation I received was to roll back the firmware ( have no idea how to do that) but since this was supposed to be a security update I didn't think that was a good idea.
After I replaced the R7900, all the issues went away including a mysterious wireless printer issue that I had not associated w/ the R7900.
One can get a very nice X3000 router for under $120.00 in the US. I thought my network security and time was worth at least that.
- michaelkenwardJan 04, 2022Guru - Experienced User
Read the manual or follow this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
.... since this was supposed to be a security update I didn't think that was a good idea.While that approach makes much sense, it might help to have a bit of background. Those "security updates" are often in response to someone somewhere in an academic computer lab or a maker of security software, setting out to break things. They then pass this detail on, even though no one has seen evidence of these exploits in the wild.
In some cases, military systems, for example, it is important to fix those holes. But for many users the threat to a domestic network is minimal.
Think of it as someone in a research lab on the other side of the planet finding a Covid variant that has yet infect anyone. They then tell the world about this and medics rush to find a vaccine for something that might not even be infectious.
So, while it makes sense to keep up to date with security fixes, for many users a cost-benefit analysis might suggest that living with the theoretical threat is preferable to struggling with a router that doesn't do its job properly.
The choice is yours, but best made from knowing what is going on.
