beachy24
Oct 18, 2017Aspirant
Intermittent WAN connection - view logs of connectivity?
Hi Folks, I am having intermittent connectivity problems. Essentially, anywhere from 15-20 minutes up to 2-3 hours of uptime then I lose my internet connection on all my devices. I can't browse the ...
- Oct 19, 2017
SOLVED.
I think either the Coax connection had degraded or the cable modem was bad. I am pretty sure it was the coax connector though. I replaced it with a new one and things seem back to normal. I also replaced the cable modem but that did not seem to do the trick.
beachy24
Oct 19, 2017Aspirant
SOLVED.
