arloman2
Apr 02, 2016Follower
Internal concrete walls - do any Netgear Routers/Extenders support 802.11k?
I'm currently using a primary router / access point with two additional routers set up as range extender access points (AP). These are configured for 2.4GHz only with connections to 300Mbps. All ar...
- Apr 02, 2016
I don't think any of Netgear's Routers and Extenders support seamless fast handoff.
Doing some research, I found that the Wi-Fi Alliance has a Voice Enterprise certification that requires support for 802.11k, 802.11r and 802.11v (helpful link with whitepaper). You can search their database for products that have received this certification. Here is the list of routers (link).
Note: There is a Voice Personal certification, too.
TheEther
Apr 02, 2016Guru
