jeremystitt's avatar
jeremystitt
internal DNS resolution
Is it possible for the R8000 router to forward DNS lookup requests to an internal server?  I want a host name to resolve differently internally vs externally.   From what I can tell, the R8000 alwa...
  • JamesGL's avatar
    Sep 24, 2015
    Hi jeremystitt,
    Welcome to Community!
    It is possible if there is another DHCP server in the network that will manage all the IP and DNS. If there is another DHCP server then you can disable the DHCP of the router.
    JamesGL
    Community Team
