aravapalliarun
Dec 22, 2020Aspirant
Internet & WIFI lights not coming after R6350-AC1750 Smart WiFi Router Firmware updated to 1.1.0.78
Hi, I have update my Netgear R6350-AC1750 Smart WiFi Router firmware from 1.1.0.76 to 1.1.0.78. After doing that, the Internet & WIFI lights not coming. Could someone please help on this? Th...
aravapalliarun
Thanks for your response.
Only Power light(Green) light is blinking and rest other lights not blinking.
When I connect the internet cable to my laptop, internet is working. So no issues with the internet.
I tried with reset option but there was no response from the device.
Dec 22, 2020Guru - Experienced User
If internet is working, are you able to log into the router using the gui?
Are you able to ping it?
- antinodeDec 22, 2020Guru
> blinking.You may be a candidate for the TFTP recovery scheme. See, for
example:https://community.netgear.com/t5/x/x/m-p/1622096#M102004
> gui?Read it again. "The Internet" and "my router" are spelled
differently for a reason.
