BCM891's avatar
BCM891
Follower
Sep 15, 2022
Internet access between R7000 and LG smart TV
I recently changed my NETGEAR password and have internet access with my iPhone and iPad.  My 6 year old LG TV does not recognize the password (or the previous one).  Any suggestions how to fix?
  • FURRYe38's avatar
    Contact the TV mfr for help and support regarding there product.
    Check for TV FW udpates.
    Check SSID name and PW configuration. Try a simple SSID name thats just one word and a simple all alpha character password with 8 characters.
    What Firmware version is currently loaded on the NG router?
  • michaelkenward's avatar
    michaelkenward
    Are you using the TV's setup routine?
    Does the TV have a "reset" option to wipe out old settings?
    BCM891 wrote:
    I recently changed my NETGEAR password ....
    I assume that this is the wifi password and that the TV can detect the wifi.
