Retired_Member's avatar
Retired_Member
May 21, 2019
Internet connected / Time synchronized every 6hrs drops connections
Greetings to one and all, Been happening for months now, I can time it to the second as to when my IPTV locks up lol I've checked logs and seen that I had an intruder through the Upnp (so disabled...
  • myersw's avatar
    myersw
    May 22, 2019
    IP address renewal happens all the time on networks. A renewal of IP address of the WAN interface on the router should not cause a pause in the IPTV. I would look at the router and specifically the router firmware. It might be worth the effort to go to an older version of the firmware. Do you know of a version that seemed to work for you? If so I would reinstall that. You could try a hard reset, but not really sure what that would accomplish in this case, but who knows?
