JTG123's avatar
JTG123
Tutor
Jan 18, 2022
Internet connection failure?
I just bought this modem. I powered it up, connected it to the coax internet cable, and waited for the world light to show up. Instead, it's been sitting at a downstream blinking light for an hour wit...
  • plemans's avatar
    Jan 19, 2022
    when you log into the modem, you can click the internet icon and it'll take you to the cable connections page.
    the event log is under the advanced tab
