JTG123
Jan 18, 2022Tutor
Internet connection failure?
I just bought this modem. I powered it up, connected it to the coax internet cable, and waited for the world light to show up. Instead, it's been sitting at a downstream blinking light for an hour wit...
- Jan 19, 2022
when you log into the modem, you can click the internet icon and it'll take you to the cable connections page.
the event log is under the advanced tab
Jan 19, 2022Guru - Experienced User
sorry, mean provision the modem, not router.
JTG123
Jan 19, 2022Tutor
Yes. I called comcast and they switched it over, but even after it was provisioned nothing changed on my netgear modem. I know the coax cable works, as it had been working with comcast up until the moment I unplugged it from their router/modem.
