JTG123
Jan 18, 2022Tutor
Internet connection failure?
I just bought this modem. I powered it up, connected it to the coax internet cable, and waited for the world light to show up. Instead, it's been sitting at a downstream blinking light for an hour wit...
- Jan 19, 2022
when you log into the modem, you can click the internet icon and it'll take you to the cable connections page.
the event log is under the advanced tab
JTG123
Jan 19, 2022Tutor
I'll be honest I'm not sure what that is. I could send a picture of my network and connections setting mon my computer showing no connection of that's what you mean.
Jan 19, 2022Guru - Experienced User
