carbo01
Nov 14, 2021Follower
internet connection with no wifi with AX12 RAX120
With my AX12 RAX 120 I have internet via ethernet connection but no wifi. When I select advanced -wireless settings- advanced wireless settings I am unable to ENABLE WIRELESS ROUTER RADIO (this action is currently disabled until the wireless On/Orff button is pressed).
I have turened my Nighthawk upside down and inside out and I still have not foud the On/Off button. Can someone help?
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6Try a factory reset by pressing the reset button for 10 seconds then release.
Thank you. - plemansGuru - Experienced User
