Saucetradamus
Oct 18, 2021Aspirant
Internet Crashes
Recently bought the Nighthawk AC2100, set it up as per the instructions and after some minor glitches, got it working. After about a day or two of it working, I woke up this morning and all my interne...
Oct 18, 2021Guru - Experienced User
From the sound of it, your modem is a modem/router combo device. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
- SaucetradamusOct 18, 2021AspirantTried those solutions, modem is in bridge mode (non router mode) still not allowing access to internet???
I am very confused with this- plemansOct 18, 2021Guru - Experienced User
when you switched it to bridge mode, did you power off the modem and let it sit for 2 minutes. then power it back on, give it a couple minutes, then connect the router to it and attempt setup?
if so, then try one of the other modes. It wouldn't be the first time I'd seen a bridge mode not work properly
