Saucetradamus
Oct 18, 2021Aspirant
Internet Crashes
Recently bought the Nighthawk AC2100, set it up as per the instructions and after some minor glitches, got it working. After about a day or two of it working, I woke up this morning and all my interne...
Saucetradamus
Tried those solutions, modem is in bridge mode (non router mode) still not allowing access to internet???
I am very confused with this
Oct 18, 2021Guru - Experienced User
when you switched it to bridge mode, did you power off the modem and let it sit for 2 minutes. then power it back on, give it a couple minutes, then connect the router to it and attempt setup?
if so, then try one of the other modes. It wouldn't be the first time I'd seen a bridge mode not work properly
