cmkhetwal's avatar
Jun 08, 2020
Internet Drop and Does not connect to PPPOE
Hi Team,   i bought this new router netgear AC1750 Smart Wifi Model R6350. this router does not connect directly with PPPOE connection. also if connect it via DHCP from the other router then also t...
  • cmkhetwal's avatar
    cmkhetwal
    Jun 15, 2020
    Hi ,
    Its connected now and working fine. the problem was with the ISP side for PPPOE. Actually we have to use static ip from the ISP side with netgear router. in other routers dynamic IP is working fine.
    so today i asked the ISP to give me the static IP, then i connected my netgear router directly via PPPOE and it worked.
    Thanks
