Ajaz
Dec 09, 2021Guide
Internet drops on Nighthawk x6 R8000 (wifi is working)
Hi, My trusted Nighthawk R8000 which I've been using for several years has started to play up recently. It is currently connected to a BT Openreach device with a BT Broadband Fiber 2 package. Is...
Ajaz
Dec 12, 2021Guide
Hi FURRYe38,
The ISP is no help because they don't support third party routers. I have a standalone PC connected using a LAN Cable (cat6) which also losses Internet access. This PC is one of the reasons I use the R8000 because I remotely access this device when working remotely and have RDS - Port Forwarding configured.
My set up hasn't changed over the past 6 years the only thing that has is the ISP and most recently BT installed the ONT device when I signed up to them. The problem started occurring as soon as I started with BT (moved from Virgin Media).
I've looked up the OPENREACH ONT device (Nokia modem) and it appears to be just a modem.
Dec 12, 2021Guru - Experienced User
IF the problem started with the installation of the ONT on BT and it worked prior to this, the ISP needs to look into there signal line and check there logs for any odd issues seen on there line UP to and including the ONT.
Has a factory reset been performed since the ONT was connected and setup from scratch? I'd power OFF the ONT for 1 minute as well then back ON. Complete the setup wizard. Don't enable Armor, Access Controls or Traffic Meter. Ensure Time is set correct and DST.
- AjazDec 12, 2021GuideYes, I did a full reset on the router and restated the modem as well. I did this after I got fed up with having to restart my router every day.
The problem got solved for a few days but then reappeared.
Now, its back to being painful again as the router needs a restart every other day.- FURRYe38Dec 13, 2021Guru - Experienced User
Others have mentioned that recent FW is problematic. You may need to downgrade the FW to something prior...
- AjazDec 14, 2021Guide
Any suggestion where to download the Firmware from and which version?
I need to sort this out asap because when I'm not at home it is impossible to switch the router off/on to make it work again. Can't put a smart plug on it because the plug will also be offline. So I'm completely stuck!
