Ajaz
Dec 09, 2021Guide
Internet drops on Nighthawk x6 R8000 (wifi is working)
Hi, My trusted Nighthawk R8000 which I've been using for several years has started to play up recently. It is currently connected to a BT Openreach device with a BT Broadband Fiber 2 package. Is...
Dec 15, 2021Guru - Experienced User
I found this:
Might try v28 if your router doesnt' seem to keep stable.
Ajaz
Dec 15, 2021Guide
FURRYe38,
Thanks for all your help so far! So...
I reset the router.
Downgraded to version V1.0.4.28_10.1.54.
Reset the router again.
Then did a clean set up.
Fingers crossed for tomorrow.
- FURRYe38Dec 15, 2021Guru - Experienced User
đ
- AjazDec 17, 2021Guide
Unfortunatley, the problem still persists. Internet seems to grind to a hault. Multiple issues with internet connectivity as appose to wifi connectivity.
Last night out of desperation I've had to install the BT Smart Hub 2. Managed to give my PC a static IP and got the RDP working so all good for now.... but a shame that my faithful R8000 (have had it for 5yrs) is not compatible with my current set up :(
- FURRYe38Dec 17, 2021Guru - Experienced User
What happens if you configure the router for AP mode with your ISP router?
