Pchrist
Mar 25, 2021Aspirant
Internet dropsNighthawk X8 R8500
Every few days our internet connection on the router just drops and doesn't come back till we reboot the router. Any ideas or suggestions as to what it could be? Running firmware 1.0.2.144 any he...
Mar 25, 2021Guru - Experienced User
What modem is it connected to?
When it drops, are you still able to access the router?
Are you able to ping/access the modem when it drops?
Pchrist
Our town has fiber internet comes right into the house to router. It says connected to router but when i go to the nighthawk app it won't connect to the router. When i try to remote access from my phone on cellular, it also won't connect. We reboot it and it is back up no issues.
- plemansMar 25, 2021Guru - Experienced User
Whats that fibre connected to? (since the R8500 doesn't have a fibre input)
- PchristMar 25, 2021Aspirant
Town provides a box outside that turns it from fiber to network cable. It's outside so not sure it's a modem but it must be of some sort.
Have you checked with the ISP to see if they require any specific settings with their service and ONT?
