cota447
Aug 05, 2021Follower
Internet Lag with videogames
I have very fast wifi of about 900 mbps. But when i load up a video game I begin to lag and my mbps drops to around 100. It did not always do this. i thought i was being throttled so i got a vpn and ...
michaelkenward
Aug 06, 2021Guru - Experienced User
I doubt it. Just because something says 900 Mpbs on the label does not mean that everything will work on wifi at that speed.
If you really do mean wifi, then very few wifi clients will deliver 900 MBbps. A 2.4 GHz wifi signal will find it almost impossibe to go that fast. 100 Mpbs is pretty good for some clients on 2.4GHz.
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
How fast is your Internet service?
If you want fast access, then a wired connection is the best option.
