BandD's avatar
BandD
Internet LED light is redbud still have internet service
The internet LED light on the router is solid  red yet still have full internet service.  Connected to iMAC, use Cox internet service
Need help - thanks
  • FURRYe38's avatar
    There a model # of this router?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • plemans's avatar
    What modem/gateway is it connected to?
    Half the time I see the internet led red but internet working fine its because of a double nat.
    A couple nat is when your running more than 1 router
