rags1
Aug 18, 2020Aspirant
Internet LED
Router LED blinking amber. Wireless is dropping throughout house even on computer in same room as router. Hooking modem to router by ethernet gives excellent download speed but doing the same from t...
- Aug 18, 2020
Your model is R7960p correct? cause I don't see a R7960 in the support page. I do see a firmware update on the page for a R7960p https://www.netgear.com/support/product/R7960P.aspx#download You can manually download the firmware and apply it on your router by doing it hardwired.
rags1
R7960 Nighthawk X6S AC 3600. It keeps erasing it from the model # space.It is the internet LED.
wcalifas
Aug 18, 2020Prodigy
