SteveDavisPsyD's avatar
Jul 16, 2021
Internet light is
I have internet to the modem and can bypass the router to my MacBook. The router lights are on and it is broadcasting. However, the internet light is red/amber and flashing or is on continuously. I h...
  • SteveDavisPsyD's avatar
    SteveDavisPsyD
    Jul 16, 2021
    Remembered to use the Netgear Nighthawk app and apparently needed to reconfigure the router. Everything is working fine.
