Mediaone1
Feb 10, 2021Follower
INTERNET NETGEAR WIFI BOOSTER
I have had to change my desk top and now the internet wont work on the other small intenet wifi booster
As it was bought 12 months ago Net gear wont help
Any thoughts
What actual extender model do you have?
What router is it connected to?
What firmware is on the extender?
Did you try factory resetting and reinstalling?
Mediaone1 wrote:
I have had to change my desk top and now the internet wont work..
Tell us a bit more. "Won't work" could mean many things.
How is it trying to connect? Wifi? Wired Ethernet?
What messages do you see when you try?
Is it a Windows PC?
Try running the Network Troubleshooter in Windows.
Start here:
Fix network connection issues in Windows 10
Probably because there is nothing wrong with whatever Netgear device you are trying to connect through. Sounds more like a problem with your new desktop. Netgear can't do anything about that.
