KranthiKumarKVS's avatar
Mar 03, 2022
Internet not available on phone but laptop is working with internet
From last night when using the same wifi for laptop and mobile, the internet is not available only on the mobile devices and laptop is having internet at the same time. I am not sure why the internet is not working for mobiles only.
Firmware Version
V1.4.2.84_1.3.42
  • plemans's avatar
    what modem/gateway are you connected to?
    Did you try a factory reset/reinstall?
  • michaelkenward's avatar
    michaelkenward
    Which mobile devices?
    How does "not working" manifest itself? Error message? Prompt of some sort?
    When some devices connect but others don't, it is a good idea to look into the reluctant device rather than the router, which is clearly doing its stuff.
