lefty9
Mar 14, 2021Aspirant
iOS 14.4.1
I recently upgraded iphone to iOS 14.4.1. I have the Nighthawk app on the phone which worked previously. App version is 2.8.5.16. I was able to logon to the router but the device manager did not work...
LizaLeung
Mar 17, 2021Aspirant
I also face the same problem after upgrading iOS 14.4.1 on my iphone, I just can't gain access to the wifi network. I guess Netgear need to fix the app to be compatiable to the new iOS.
antinode
Mar 17, 2021Guru
> [...] It gave me a failed message (i cannot remember the exact
> wording). [...]
Have you considered the possibility that the actual error message
text might contain some useful information?
> I also face the same problem [...]
Did you get the same error message?
> [...] I guess Netgear need to fix the app [...]
Which "the app"?
Possibly interesting:
- lefty9Mar 23, 2021Aspirant
Uh I don't think the message "Login failed" is very meaningful. It doesn't seem to provide some useful information. Again the Nighthawk app worked until I installed iOS 14.4.1. Has anyone else encountered this?
