noparity's avatar
noparity
Follower
Aug 04, 2021
IP address via ethernet sometimes in DMZ?
Hello!  I've now twice experienced an issue where my IP address isn't assigned from my router but my ISP, as though my machine is in the DMZ (I have no machines in the DMZ).  The first time it happened was running firmware version 1.0.2.80.  I have since updated to 1.0.2.82 and was fine for a few months but it happened again today.  The machine is connected to the router via ethernet cable.  Release/renewing the IP address doesn't resolve the issue, I have to reboot my router.  Anybody else experienced this, is it a known issue?  I did a little searching but couldn't find anything.
1 Reply
  • > Model: R7800|Nighthawk X4S AC2600 Wifi Router
       Connected to what?
    > [...] I've now twice experienced an issue where my IP address [...]
       "my"?  _You_, personally, have an IP address, or do you mean the IP
    address of some computer/device which is connected in some way to
    something?
    > [...] isn't assigned from my router but my ISP, as though my machine
    > is in the DMZ (I have no machines in the DMZ). [...]
       A DMZ server on these routers has a LAN IP address.  Whatever's
    happening in your case, it's not like DMZ server on the router.
    > [...] The machine is connected to the router via ethernet cable.
       That excludes a few unlikely possibilities.
    > [...] Anybody else experienced this, [...]
       It proves little, but I don't remember seeing any similar complaints.
       If you can catch it in the act, then I'd try a little more
    exploration of what else it does (or doesn't do), if you can find a way
    to talk to it.  My guess would be that the router firmware is getting
    bewildered in some way -- flipping into wireless-access-point mode, for
    example, or something even less organized.
       Various problems can be caused by bad firmware exhausting some
    resource over time.  My D7000 freezes after about a month, for example.
    But your symptom is funnier.
       I wouldn't expect a settings reset and manual reconfiguration to
    help, but I'd still try it.
