manjulapra
May 12, 2021Aspirant
IP range mixup
Hi, Recently switched my modem. Got a ATT modem+router. Did a passthrough and configured the network. When I hooked up, router picked 10.0.0.1 as the IP range, probably due to a conflict before I...
- May 13, 2021
Thanks for the help. I was able to resolve by configuring a different IP range for the modem. It seems the ATT modem does not function just as a modem.
microchip8
May 12, 2021Master
Did you unplug these devices and then plug them in again?
What firmware is on the router?
If your modem is in bridge mode, the router should use its default 192.168.1.1 address
