manjulapra
May 12, 2021Aspirant
IP range mixup
Hi, Recently switched my modem. Got a ATT modem+router. Did a passthrough and configured the network. When I hooked up, router picked 10.0.0.1 as the IP range, probably due to a conflict before I...
- May 13, 2021
Thanks for the help. I was able to resolve by configuring a different IP range for the modem. It seems the ATT modem does not function just as a modem.
antinode
May 12, 2021Guru
> [...] Got a ATT modem+router. [...]
Not a very detailed description. Maker? Model number?
> [...] When I hooked up, router picked 10.0.0.1 as the IP range,
> probably due to a conflict before I set the passthrough [...]
Plausible.
> [...] but I am fine with it.
Apparently not.
> [...] I don't know why their IP addresses did not automatically
> change. [...]
Only one of us was there when their addresses were assigned.
> [...] I wanted to give 10.0.0.x IP for the camera and PiHole but can't
> fine a way how.
To me, that sounds like a camera and/or Pi-hole question, not a
router question.
If your (unspecified) a ATT modem+router really isn't occupying the
"192.168.1.*" subnet now, then why not configure the R7800 to use it,
and stop worrying about the camera and Pi-hole?
manjulapra
May 13, 2021Aspirant
Thanks for the messages. I ATT Router model model is BGW320-505
The ATT router is occupying 192.168. range. I am not certain how to turn that off. Do I thrun off DHCP Server?
See the attached image
Thank you again!
- michaelkenwardMay 13, 2021Guru - Experienced User
Try this:
bgw320-505 bridge mode - Google Search
Not all modem/routers (or gateways) let you use modem only mode. But those search results might help.
- manjulapraMay 13, 2021Aspirant
Thanks. I did read most of these pages but couldn't find information about enabling or disabling the DHCP Server.
I am not sure why Netgear router assigned an out of range IP to the camera. Anybody has an answer to that?
I doubt if it did that. You should be able to tell the camera to use whatever IP address you like.
Netgear hasn't picked anything "illegal". It is just following the rules. 10.0.0.1 is "a reserved IP address for the private network of class A".
10.0.0.1 as the IP range - Google Search
You might do better to talk yo the people who made the cameras:
Probably the wrong question. Investigate "bridge mode".
