manjulapra
May 12, 2021Aspirant
IP range mixup
Hi, Recently switched my modem. Got a ATT modem+router. Did a passthrough and configured the network. When I hooked up, router picked 10.0.0.1 as the IP range, probably due to a conflict before I...
- May 13, 2021
Thanks for the help. I was able to resolve by configuring a different IP range for the modem. It seems the ATT modem does not function just as a modem.
manjulapra
May 13, 2021Aspirant
Thanks for the messages. I ATT Router model model is BGW320-505
The ATT router is occupying 192.168. range. I am not certain how to turn that off. Do I thrun off DHCP Server?
See the attached image
Thank you again!
michaelkenward
May 13, 2021Guru - Experienced User
Try this:
bgw320-505 bridge mode - Google Search
Not all modem/routers (or gateways) let you use modem only mode. But those search results might help.
- manjulapraMay 13, 2021Aspirant
Thanks. I did read most of these pages but couldn't find information about enabling or disabling the DHCP Server.
I am not sure why Netgear router assigned an out of range IP to the camera. Anybody has an answer to that?
- michaelkenwardMay 13, 2021Guru - Experienced User
I doubt if it did that. You should be able to tell the camera to use whatever IP address you like.
Netgear hasn't picked anything "illegal". It is just following the rules. 10.0.0.1 is "a reserved IP address for the private network of class A".
10.0.0.1 as the IP range - Google Search
You might do better to talk yo the people who made the cameras:
Probably the wrong question. Investigate "bridge mode".
- antinodeMay 13, 2021Guru
> turn that off. Do I thrun off DHCP Server?If those settings are active, then "Did a passthrough" seems not to
be true. Or your definition of "passthrough" doesn't match the usual
one.Presumably, there are instructions someplace for configuring the
BGW320-505 as a modem-only ("bridge" mode). Disabling its DHCP server
would not stop its router from functioning, which is what you want.
> I did read most of these pages [...]Thanks for the helpful links. With my weak psychic powers, I can't
see what you read.> [...] but couldn't find information about enabling or disabling the
> DHCP Server.
Forget about the DHCP server on the BGW320-505. How to disable it
looks pretty obvious to me on the picture you provided, but, as stated
above: Disabling its DHCP server would not stop its router from
functioning, which is what you want.> I am not sure why Netgear router assigned an out of range IP to the
> camera. Anybody has an answer to that?Why blame the Netgear router for that?
> Only one of us was there when their addresses were assigned.
Still true.
> Probably the wrong question. [...]
Not "Probably"; _certainly_.
