Paulc35's avatar
Paulc35
Ipad pro and ipad 4 shows connected, but no internet connectivity
I have the latest firmware.  I have android, windows 10, numerous wireless Tvs and two ipads. ipad 4 and a ipad pro.
Everytime we go to pick one of the ipads up and open a browser nothing loads.  Wifi shows its connected rather its 2.4, or 5ghz. you have to manually disconnect and reconnect to get back on the internet.  I haven't found anything on search. If anyone has any suggestions I would appreciate it.  This is the only Netgear router that I have had constant issues. The other devices are working fine when the Ipads arent connected.  All updates are up to date.  I have a motorola cable modem
  • > I don't know how to roll back the firmware, [...]
       Visit http://netgear.com/support , put in your model number, and look
    for Downloads.  Under Firmware and Software Downloads, look for View
    Previous Versions.  Download the kit you want.  Read the "Release Notes"
    file for instructions.
    > [...] bad design [...]
       Defective firmware can cripple the best hardware.
No RepliesBe the first to reply
