edwardstuff
Dec 05, 2022Follower
IPHONE 13 pro Max dropped call issue
Using Netgear X6 R8000 Netgear EX7700 extender my iphone 7 never had a problem, always used Smart Connect Now I always have Issues especially with sending pictures, take forever to send. Calls ...
Dec 05, 2022Guru - Experienced User
are you using icloud relay or private mac/ip address?
those can cause issues?
if you unplug the extender, do you still have issues (trying to determine if extender issue or router issue)
What firmware is on the router?
What modem/gateway is the router connected to?
